wood pellet boiler's
fitzyfitta
Member Posts: 5
I have a friend who is looking to install a pellet fired boiler. Does anyone has any pdfs or brochures for the Buderus model or any other mfg's. TIA Fitz
here you go....
not sure of availability. http://www.buderus.de/sixcms/media.php/1156/90108_BUD_PRoduktinfo_Festb.120900.pdf0 -
wood pellet boilers
Do you have Nat gas available to you?
check this out it might help you. http://www.woodpelletstovesboilers.com/
How are you going to heat your domestic hot water? Look at using a Noritz tankless LP gas water heater. Only uses energy when you need hot water and you will never run out of hot water.0 -
pellet boiler
No nat gas. It's my inlaw who lives in the woods. He has a oil fired with tankless and wants to tie in the pellet boiler. Thanks for the replies and link....0 -
Harman
I believe Harman makes one. I have not of anyone installing one yet. I also believe that Central Boiler has an outside pellet boiler. Good Luck!0 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
