Old Steam system
George75
Member Posts: 3
I have an old steam system that has been converted to district how water.
system has a nice old pipe system, they added a circulator to the system, (cast iron radiators).
The question is the piping on the radiators, They piped it so the hot water enters the bottom and exits the top.
Seems like you would be fighting gravity.
What is the proper way to pipe these?
RE
Not a huge concern. Ideally, the supply should enter the top, and exit the bottom. In a pumped system, there is no longer any gravity working on the water. Are the radiators heating properly?0 -
It is not ideal but it will function
There is a slight loss in heating rate when piped this way.Cost is what you spend , value is what you get.
cell # 413-841-6726
Re old steam
They have some balance issues, using Danfoss valves, but I will check on flow if this piping is ok.
Thanks,0 -
Re old steam
Thanks,0
