replace portion of condensate line from 2"steel to pvc?
jef
Member Posts: 8
can i use pvc to replace a 4ft part of the 2" condensate return line?
right now i have steel/copper on return line
No
No, you cannot use non metalic pipe on a steam system.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
thanks will use copper
can i reduce the original steel 2"portion to 1" or 1.5" for 4ft then back to exisiting copper 2" on other side(previous section replacement)
trying to go thru old 2" pipe in concrete step with 1" or 1.5" copper pipe so i dont have to rip up concrete step/s0 -
depends
Depends on how much condensate flow you have coming thru that line. 1.5" copper "may" work. If it was my job, I would not go down below that.0
- 120 Geothermal
