Basement Headroom
ARM
Member Posts: 1
I am considering finishing the basement of our home. We have a new (2 year old) gas fired steam boiler, but the original pipes to feed radiators remain. Headroom is currently an issue. How involved would it be to raise the pipes between the joists to gain valuable headroom? Several of the pipes are currently below the joists. Could the current pipes be reused? I assume they are original to the home (1914), or would it be wise to replace them? If so what would work best? Any help or advice would be greatly appreciated.
Not practical
The pitch of steam pipes is very important. It's hard to say whether a particular pipe could be moved without a picture or drawing, but in general I would say there's probably a good reason the pipe is below the joists. And if the pipe runs perpendicular---I wouldn't drill a lot of huge holes in a lot of floor joists in a 1914 house. I think you would have to use all new cut and threaded pipe to replace whatever was removed, possibly creating other problems in the process.
It may sound crazy but I think it would be easier to dig up your basement and pour a new pad than to mess with the mains or the joists.0 -
Yes and no
It can be done BUT it can also be disastrous if done incorrectly. The easiest option would be to box in the pipes(make sure that there is access to the vents that should be at the end of those pipes) . If you do have the pipes moved make sure to stipulate that the installer will not be paid if there any problems that did not exist before(i.e. banging or radiators not getting hot).0 -
Another person tried this
He hired a contractor who was confident that he knew what he was doing and could modify all of the piping and raise it out of the way. The end result was a disaster. The contractor's biggest qualification was that he had a big pipe wrench and could put large iron pipe together.... he thought he knew steam well enough that he argued with the home owner, who actually had much more knowledge than the contractor.
The end result was a disaster. As I recall, the owner really wished he had never begun the project.Dave in Quad Cities, America
http://grandviewdavenport.com0
- 110 Chimneys & Flues
- 977 Plumbing
- 387 Solar
- 17 Recall Announcements
