Very good article
DanHolohan
Member, Moderator, Administrator Posts: 16,686
Honeywell's Rich Simons in the December ICM. Thanks for making things clear, Rich!
Retired and loving it.
Thank you Dan
Provides some interesting insight into our increasingly socialist government. Heating information too!
Better stock up on those Clow Gasteam radiators now, along with my 100 Watt light bulbs.0 -
Mark Twain
As the great humorist, Mark Twain once said, "I'm all for progress, it's change that I don't like!"Dave in Quad Cities, America
http://grandviewdavenport.com0
- 167 Indoor-Air Quality
