Type of system
BettyB
Member Posts: 2
I'm not sure what type of steam heating system I have. There are supply and return pipes from the boiler, but the radiators have only one pipe. The radiators have air vents on the sides. Is this a one pipe system?
single pipe
That is a single pipe steam system.
3PSI gauge0 -
Yes
If the radiators had 2 pipes it would be called a two-pipe. There are a couple different kinds of one-pipe though. Counter flow and paralel flow, and sometimes a combination of the two. Counterflow is where the steam travels in one direction and the condensate tavels in the opposite direction. Paralel flow is where steam and condensate travel in the same direction.
You said you have a supply and a return. If the supply is downhill away from the boiler you have a paralel flow. If the supply is uphill away from the boiler its counterflow.0 -
Thanks
Thanks for the info!0
- 120 Geothermal
