Steam heat with Dunham vacuum pump
RonK
RonK Member Posts: 1
I have a large old house built in 1929 with steam heat.  This winter the boiler has begun to leak and I need to add water once or twice a day.  The boiler is probably 50 or 60 years old, so it is time to replace it.  It has a two pipe system and the condensate return line looks relatively small.  Near the condensate return tank there
is a very old-looking, very noisy pump that says on the ID plate “Dunham
Differential Pump - manufactured for exclusive use with Dunham Difr~enshal~vacm
Heating System– A fixed differential in pressure, a variable degree of vacuum.”  The pump has 2 gauges on it: the gauge on the left says “vacuum” and doesn’t move, it always reads zero even when the pump is running.  The other gauge reads ~15-20 when it comes on to return the condensate to the boiler.
I have gotten 3 estimates to replace the boiler.  One estimate proposes “Sterling feeder
pumps with receivers and Dual vacuum pump with receiver”.  The other two estimates list only “condensate tank and pump” and they say that the system doesn’t need a vacuum pump, but I’m not sure they really understand this old complicated system.  Except for the water leak, the system works fine and all of the radiators get hot.
So my question is, if I replace the boiler, does the new
system really need a vacuum pump as part of it to work right?
