Mixing CI baseboard and fin tube on same system
KAB_2
KAB_2 Member Posts: 15
Due to artistic differences, (yes that's really the reason) we're being asked to mix. Can that be done with different zones, TRV's etc. Thanks guys.
  • CMadatMe
    CMadatMe Member Posts: 3,086
    As Long
    As they are on different zones sure. You could also run them at different temps but that would depend on each rooms heatloss and the room emmitters capable output. Have plenty of systems running higher temps for fintube and lower temps for cast iron.
  • KAB_2
    Thank you
    Chris -Thanks so much, thought that was the case, appreciate the info.
