Lennox Complete heat replacement
Nottoday
Member Posts: 6
I am looking for a replacement for a Lennox HM30, this is part of a Complete heat system that has a AM30 piped into it. The HM30 is a 100K BTUH any ideas.......
I would
suggest getting a heat loss done to start. While there the contractor should be able to give you an estimate to replace your system. I would look at a mod/con boiler with air handler and indirect.0
