testing a main vent
zepfan
Member Posts: 436
what is the best way to tell if a main vent on a two pipe system is plugged up without burning yourself? just slowly unscrew it till you get steam and no air? i need to go look at a steam system on tuesday where the problem is several radiators on the top floor don't get hot and haven't for about ten years.i am suspecting a plugged main vent or too low of pressure.steam systems are very rare in our area.
turn off the system,
then unscrew the vent, and holding the vent vertical, blow up into it..if your cheeks puff out from backpressure she most likely is no good anymore..if you can easily blow thru it, then it is probably so other issue that is effecting your rads.gwgillplumbingandheating.com
Shut off the system
Gerry explained stuck closed, I will attempt to explain stuck open. Remove the vent. Turn the vent upside down, keeping it verticle, blow into it. If air will pass, this is stuck open. If the vent fails either test, sell them a new one. For a look at whats inside those vents click on this http://www.gwgillplumbingandheating.com/webapp/GetPage?pid=6100 -
More information needed
It might be best if you take pictures, make observations, then come back to the wall.
My first thoughts are that I have never seen nor heard of a steam main getting plugged up. Also, raising the pressure setting is the sign of an attempt to fix a system that is not working, withouth correcting the actual problem. Usually, the increased pressue causes more problems than it fixes. DON"T raise the pressure. Residential systems operate at 2 PSI max. Most operate quite well at 0.5 psi.Dave in Quad Cities, America
http://grandviewdavenport.com0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
