Powervent water heater electrical
ChrisJ
Member Posts: 17,070
Is it usually required for a power vent gas water heater to have its own circuit?
Thanks.
Thanks.
waterheater power venter
is water heater the only gas appliance being power vented? is it in a condo and shared by all tenents then yes0 -
Residential
And its the only power vented appliance. Boiler is nat draft and on its own circuit.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
power venter
in that case definately put it on it's own circuit so you will know its not acidently put on a switched circuit0
