mini split refrigeration line insulation recommandation
zygote
Member Posts: 1
I just recently put in few unit of fujitsu mini split system. I want to know if it's a good idea to put in additional insulation to the current refrigeration line connection to the outdoor unit.
Regards,
Zygote NYC
Regards,
Zygote NYC
Of Course!
Of course!
The more the better. Just make certain that both refrigerant lines are insulated as they are both low pressure/low temperature lines.There was an error rendering this rich post.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
