Grundfos Magna 32-100 pump
Simply Rad
Member Posts: 208
I am getting to install the Grundfos Magna 32-100 and I just thought about the flanges. Does this pump adapt to traditional Webstone isolation flanges or do you need a specific flange.
Thanks
Jeffrey
Thanks
Jeffrey
Jeffrey Campbell
If its...
anything like the 43-44 it will not.0 -
Takes
GF15/26 flanges which are the same as the Webstone. Recommend pump flg size is
1-1/4".There was an error rendering this rich post.
Thanks Chris
Where did you get the info? I searched and couldn't find it. I ordered 1 1/2" flanges so I should be fine. Thanks again
JeffreyJeffrey Campbell0 -
I Have
The full line List price book in pdf. Every pump has the appropriate flanges sizes as well as counter flanges to adapt when needed.There was an error rendering this rich post.
Cant keep up with technology
I have a grundfos 3 ring binder from 2010 and the quick reference pump guide. Neither have this pump and when i search it on google all I found were new release info. At this point I am sure nearly all my binders are outdated, except for a new Waterfurnace binder. I am excited that my Geo designer is now a Waterfurnace rep and I took a training in September and now am a dealer. Anyways its tough to keep up with all the technology changes.Jeffrey Campbell0
- 120 Geothermal
