Grundfos Magna 32-100 pump
Simply Rad
Simply Rad Member Posts: 208
I am getting to install the Grundfos Magna 32-100 and I just thought about the flanges.  Does this pump adapt to traditional Webstone isolation flanges or do you need a specific flange.
Thanks
Jeffrey
Jeffrey Campbell
  • kcopp
    kcopp Member Posts: 4,682
    If its...
    anything like the 43-44 it will not.
  • CMadatMe
    CMadatMe Member Posts: 3,086
    edited November 2011
    Takes
    GF15/26 flanges which are the same as the Webstone. Recommend pump flg size is
    1-1/4".
  • Simply Rad
    Thanks Chris
    Where did you get the info?  I searched and couldn't find it.  I ordered 1 1/2" flanges so I should be fine.  Thanks again
    Jeffrey
    Jeffrey Campbell
  • CMadatMe
    I Have
    The full line List price book in pdf. Every pump has the appropriate flanges sizes as well as counter flanges to adapt when needed.
  • Simply Rad
    Cant keep up with technology
    I have a grundfos 3 ring binder from 2010 and the quick reference pump guide.  Neither have this pump and when i search it on google all I found were new release info.  At this point I am sure nearly all my binders are outdated, except for a new Waterfurnace binder.  I am excited that my Geo designer is now a Waterfurnace rep and I took a training in September and now am a dealer.   Anyways its tough to keep up with all the technology changes.
    Jeffrey Campbell
