vitodens 100/combi wiring-TACO 503 relay
rickb
Member Posts: 1
Where do I make the outside sensor connections on the 100(lv).
Also how and where to I connect the 503 to the boiler. The only terminal block remaining is X4 for low voltage.
I have created confusion for myself I am sure. Thanks for your help.
Wiring
The 1st shipment of the new WB1B10-26 and 35s came less the 21 plug. On the LH side of the boiler if you don't see a white block that takes 6 wires its misssing. Looks like a guitar tuner. Ifnitsnthere wire sensir to terminals 3 and 4 if not there call Viessmann they will send to you. The end switch from the zone control goes to RT which has a jumper in it. Pull the jumper off and take the XX from the zone control and wire to it. Make sure priority switch in the zone control is in the off position. You can still run the boiler without ODR until you get the plug. It will take all but 2 minutes to add the plug ifnyoundon't have it.There was an error rendering this rich post.
So How
Did you make out?There was an error rendering this rich post.
- 119 Chimneys & Flues
- 116 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
