newer style Pressuretol?
2»
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,829
    No Problem in NYC
    NYC codes permit a vaporstat if the building only requires one control.  If the system requires two controls, one must be of a type that locks out on high pressure and must be reset manually.
    In NYC, the control must be installed by a licensed master electrician on a boiler installed by a licensed Master Plumber with the proper filed permits.
