Logatop BE/GB oil burner
fitter408
Member Posts: 2
in Oil Heating
I have a Buderus G115 cast iron oil fired boiler with a Riellio B series burner that is on its way out. Can I replace this with the (higher efficiency?) Logatop burner and would it be worth what I assume would be the extra cost? Thanks.
Not Available
separately as far as I know0
