Steam boiler failure
James Day_2
Member Posts: 191
I'm a hydronics guy, not steam. Went to service a 5 year old burnham today, when I went to open the top to clean the heat exchanger I found that it is completely rotted out. What causes such premature failure. Thanks James
Rotted out?
JD,
What doyou mean by "Rotted Out"? Is the boiler leaking?0 -
rotted
opened the top of boiler and the heat exchanger crumbled in my hands. giant chunks of the heat exchanger pulled off with ease.0 -
Burnham Boiler Failure
Could you post some pictures? Where are you located? Some parts of the country are having this problem due to the water.0 -
Too much make-up water
is the usual cause. Look for underground return lines, bad vents, leaky valve packings.
If this system is oil-fired, go with the Burnham MegaSteam. It was specifically designed to head off this problem. And it has the best efficiency of any residential steamer.All Steamed Up, Inc.
Consulting0
