Weil McClain boiler
Marilyn_4
Marilyn_4 Member Posts: 26
It's an older one that has a blue casing. Do you know if this is a cast iron boiler?
Marilyn
    Steamhead Member Posts: 17,898
    Should be
    what model is it?
    Consulting
  • Marilyn_4
    To do or not to do...
    I'll find out later. My daughter needs a new hot water heater. Due to the money factor the question is whether to just put another oil fired one in there or add an indirect to the existing boiler....????
  • Marilyn_4
