radiant Taco pump timing
I have a standard oil boiler that runs four short radiant zones to keep the floor cavities warm to prevent the pipes from freezing and give supplimental heat at the floor, and when the boiler cycles on and runs its time to reach the thermostats temp. the boiler shuts down the Taco water pump also shuts down, Is there a way to keep the pump running without straight wiring it? Thanks, Tom in Maine
