Burnham Holiday- where's the btu rating?
LukeC
Member Posts: 2
I have an old workhorse of a boiler- a Burnham Holiday. It runs, keeps up with the heating requirements needed in the Rockies, however I am wanting to price out a replacement system. The Boiler dimensions are 21.5"x24.5"x30.5", however I have searched high and low for a btu rating. If it helps, it has a Watts ET-30 Pressurized expansion tank attached to it and was installed in 1972. Our county is kicking in money for boiler replacement, and I would like to potentially take advantage of it. Thanks!
Heat Loss
The rating of the existing boiler is a waste of time nor would any professional replace the boiler without doing a heat loss. Don't worry about the existing boiler. have a heat loss calculated and size the replacement boiler based on the heat loss.There was an error rendering this rich post.
