Expansion tank p.s.i.
anziconda
Member Posts: 6
Anybody have a easy formula to calculate the CORRECT air pressure in a expansion tank for a hydronic system? Thanks.
It should
Be the same pressure as the water in the hydronic system when it is cold.0 -
How to set psi
Sprinter is correct, but there is a trick to setting that psi. When connected to a pressurized boiler, an expansion tank will ALWAYS have the same pressure as the boiler, unless it is higher. To check the x-tank pressure, first note the boiler's cold pressure (adjust if needed) then relieve pressure in the boiler, then check and adjust the pressure in the xtank, then repressurize the boiler.
The idea is that you only need the x tank to absorb the extra volume created when water is heated. At cold, there should be no water in the tank, preserving all its volume to absorb extyra water when the heat comes on.
Bill Clinton0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 48 Industry Classes
