Steam Boiler Sizing
JimZ
Member Posts: 8
Anyone know where i can locate a steam boiler sizing chart?, i'm going from a oil fired boiler, to a gas power vented boiler, and know i must measure radiation, and calculate everything
Boiler Sizing Chart
Hi- You need to size your replacement steam boiler to the total EDR of your system.
Here 's a couple of articles that might be of help to you:
http://www.heatinghelp.com/article/236/For-Homeowners/1490/How-to-have-a-boiler-replaced-without-getting-steamed
http://www.heatinghelp.com/article/321/Steam-Heating-Basics/128/A-Steam-Heating-Primer
I've also attached a work sheet which will help you calculate the EDR of your radiators.
- Rod0 -
re
thanks for the chart rod!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
