Hydronic access port
Bill H.
Member Posts: 30
I want a port for pouring boiler cleaner/inhibitor solutions into my boiler piping system. My baseboard emitters have no vents. My thought is to obtain a T-fitting type of device that has a screw in cap to allow access to the system. My piping is 3/4 copper, so I guess a sweat fitting would be required. Anyone know if such a port is available? Otherwise, how can get the needed access? Thanks for any input, Bill
If you need....
to add in cleaner, inhibitor, etc.....that should be done through a boiler drain on the boiler and use a transfer pump.0 -
Quick and Easy way of inducing chemicals into a system...
Go to Home Depot, and purchase their small manual hand pump, and the fittings necessary to get you from their discharge hose to a 3/4" female hose adapter.
Turn off the make up water, and bleed the system pressure to 0 PSI. Connect hand pump to drain cock on system, and start pumping chemicals in. If another remote drain cock is available, let out the same amount of fluid you are pumping in. Once done, disconnect hoses, and turn makeup water back on. Done properly, you will get very little air into the system, which should self purge.
http://www.homedepot.com/h_d1/N-5yc1v/R-202277592/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Good luck.
ME0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
