Circulation in oversized gravity heat lines
RLB
Member Posts: 2
does anyone know what it is called when you get circulation in an oversized
gravity heat line
gravity heat line
terminology
thermosiphoning?--nbc0 -
if its a gravity....
hot water system then the lines are not oversized.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
