Circulation in oversized gravity heat lines
RLB
Member Posts: 2
does anyone know what it is called when you get circulation in an oversized
gravity heat line
gravity heat line
terminology
thermosiphoning?--nbc0 -
if its a gravity....
hot water system then the lines are not oversized.0
