Vent doesn't seem to close on main riser
Cahill
Cahill Member Posts: 4
I installed a Jacobus #1 main steam vent just before the riser.There had been one there that was plugged.It doesn't seem to close and it blows steam. How exactly is it supposed to function ? At what point should it close? Should it be blowing steam?
  • Tim_Hodgson
    Tim_Hodgson Member Posts: 60
    Leaking steam vent
    Since it is new, I would check to make sure the vent is plumb. I would also check if dirt, pipe dope or teflon tape could have gotten inside the vent. Do you have any water hammer when the system fires up?
    Good Luck,
    Tim
  • LarryC
    LarryC Member Posts: 330
    Vent blowing steam
    Basic question.
    What pressure are you operating the system at?  Hopefully less than 2 psi.
  • Cahill
    Problem solved Defective air eliminator vent
    Maid of the mist #1 defective.It looks like another crappy product probably made by slaves in some third world country
