UL 778
TC_2317
Member Posts: 1
Recently on commercial projects I'm seeing a requirement for UL 778 on pump motors. My question is "are there any manufacturers with UL 778 listing for their pumps?"
UL 778
Not to sound stupid but what is UL 778?0 -
UL778
Is the product safety standard for Motor-Operated Water Pumps.
The scope of products covered is:
1 Scope
1.1 These requirements cover submersible and nonsubmersible motor-operated pumps intended to be
used in ordinary locations in accordance with the National Electrical Code, NFPA 70.
1.2 These requirements do not cover pumps rated more than 600 volts, pumps using universal motors
rated more than 250 volts, pumps for fire protection service, pumps for use as or with swimming or wading
pool equipment, therapeutic baths, and similar equipment, nor pumps covered by other individual
requirements. These requirements do not cover pressure controls or pressure tanks that are intended for
use in water or other liquid systems.
1.3 A pump not covered by any of the definitions in Definitions, Section 3, and a pump intended for use
with liquids other than water, shall be evaluated on the basis of its compliance with the requirements in
this standard,0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
