DIRECT VENT BOILER ON STEAM SYSTEM
Isi
Member Posts: 7
in Oil Heating
Does anyone know if they make Direct Vent Gas Boilers on a Steam System. The Chimney runs right through my kitchen and I would love to remove it. The Direct Vent Boiler would really help me out
you might want to
post this thread in the gas section or main wall posting area to get a response. Be it oil, I could have given you some direction. Good luck0 -
SORRY
Sorry for the mistyping not sure what I had in my mind at the time. I have a OIL boiler in a one pipe Steam system and looking into getting a new boiler in the near future so I've heard about these Direct Vent Boiler and would like to know if possible in my case0 -
not familiar
with a direct vent gas boiler but another option would be to add a power venter to a boiler. I personally am not a fan of them because it's another motor running which creates noise but it may be an option for you...Make sure to get the stainless, it holds up longer.
http://www.fieldcontrols.com/venting.php0 -
Burnham makes
a direct vent gas for steam.Cost is what you spend , value is what you get.
cell # 413-841-6726
as does Smith....
http://www.smithboiler.com/html/direct_vent_boiler_home_heat.asp
Chimneys are a good thing though... I would keep it. less issues down the line.0
