switched supply and return
Del
Member Posts: 52
for a Beacon Morris toe kick heater running on a monoflow system. I was helping a friend install one on his system using the existing monoflow tees, and the original installers used the monoflows "backwards" i.e. the monoflow tee is on the supply, and the standard tee is on the return (I've seen them done both ways). I should have studied the system a bit more before I did the job, oh well. Is there any sort of check valve in these heaters that would cause a major problem? This is for supplemental heat only, and we have not tested it yet because we still have more work to do on the system. Thanks!
-Mike
-Mike
No Checks
Seen many piped backwards, Never seen a check , but air with a mono pipe, better have a bleeder on it.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 962 Plumbing
- 385 Solar
- 15.3K Strictly Steam
