RFI on Bryant autofill unit
AdamSwapp
Member Posts: 18
I'm looking for info on an old Bryant auto-fill unit (see attached picture).
It could likely use a rebuild (if that's even possible), but I know very little about it. Would anyone know anything about age, model, manuals, diagrams, adjustment procedure, internal workings, etc.?
Thanks.
Thanks.
not sure that's an autofill
From the left face of it it looks more like an air-eliminator, and float assy. There is the sight glass installed which is to show the water level. Is there another component of this that you do not have a pic of? Or take a look around the piping near that component and see if it looks like anything could have been removed or modified. Can you take a pic of the "left face" of the component? If you take a look at this,http://www.heatinghelp.com/forum-thread/136523/guts-of-a-marsh-boiler-return-trap-with-pics it is possible to open them up and clean the inside components of them, so you might not need a full rebuild. Good Luck, Dee.There was an error rendering this rich post.
- 120 Geothermal
