gas fired boiler
gwh
Member Posts: 1
Why does the expansion tank require an isolation valve between it and the boiler?
Why does the water intake pipe need isolation valves on both sides of the back flow valve?
Both examples required for easy removal/replacement? Safety?
service
When you have an issue it is much easier to replace them this way...0
