unico system
polcat1p
Member Posts: 28
hello
i have a unico mc2430/mb2430 system. i dont have a compreser yet, and was wondering what would be a good buy. may be a good heatpump?
Heat pump
I would make sure you have a heat pump coil (mc2430h). Unico has a different dx coil for heat pumps. I would recommend 13 or 14 seer maximum. A higher seer condensing unit would not achieve and greater efficiency. Also warranties on the condensing unit may be reduced because it is not part of a "ahri matched system"0 -
unico system
thanks
its a 2430hx.0 -
410a unico tx valve
was also wondering if my unit has the 410tx valve. i assume it does, because i have all the paper work, and they used a american standard heat pump that has 410. i looked at the valve and see a few numbers
45 zga
bp/15
4405
none of these seem to match the a00808-012 the book says.
im also still looking for a good match heatpump for this unit, any ideas?
thanks0 -
unico
maybe just going to do ac only. what is a good seer and model condenser/
thanks0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
