Old Farm house radiant heat
saber
Member Posts: 9
I live in a large old farm house with radiant heat. It has a single line momo flow system. I am wanting to shut off two rooms and bypass the radiators. Can I use a Three way zone valve and thermostat to keep the temp around 60 degrees. If so where can I purchase this and also a good brand name?
You have ...
free standing radiators? If it has a mono flow set up you should not shutoff radiators. It will be too restictive. You need to have a bypass loop on those radiators... that involves some repiping.0 -
zone valve
Does th three way zone valve allow for a bypass. Repiping is not a problem.0 -
taco
http://www.taco-hvac.com/en/products/560%20Series/products.html?current_category=111 here's one with a bypass...0
