Free Radiators in Des Moines, Iowa
<span>I just received and e-mail regarding free radiators in Des Moines, so I am posting it here.</span>
<span>Ornate Radiators Available from the Wellsport/Portwell Flats 19th and Woodland. Radiators will be set outside in the parking lot on Friday October 7th. Call Sonja Roberts to view and pick up before 515-208-5413. These could be repurposed as table supports, workbench bases or just as period decoration.</span>
Dave in Quad Cities, America
http://grandviewdavenport.com
    Steamhead Member Posts: 18,213
    Another
    desecrated building!
    Consulting
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Agreed
    I agree that the heating system should have been saved!  However, I'd rather see the radiators reused than taken for scrap.
