what the !***%$#! is this
Mike S_3
Member Posts: 8
anyone have an idea what this is? it is on a steam sysyem in a basement and is connected to the condasate line neat the boiler
It's the main air vent
which works by differential expansion.
This is a Kriebel system. The vent is probably connected to a float trap that closes if water rises into it. The radiators have little check valves called "bafflers" at their outlet connections. The whole system can run on a few ounces pressure- a Vaporstat is a must!
Read about the Kriebel system in chapter 15 of "The Lost Art of Steam Heating".All Steamed Up, Inc.
Consulting0
- 120 Geothermal
