Balance Valve Probes
152NP
Member Posts: 49
Does anyone know if Taco Acu-Flow balance valves use the same test probes as B&G circuit setters balance valves?
Probes
Last one I put in had 1/4" Flare connections, which used to be fairly standard.0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
