Competent help in Southern New Jersey
Tom Asaro
Member Posts: 18
I have a 7.5 year old Peerless Pinnacle PI-140 that went dark on me yesterday. The LED on the control board continuously flashes while the zone controller and low water cutoff appear to no longer have power.
I had trouble finding a contractor that was familiar with this boiler back when it was installed, and seem to be striking out again now. The contractor search also comes up empty when searching within 50 miles of 08050.
So, is anyone within range or can you recommend someone that is?
Thanks,
-Tom
Thanks,
-Tom
Broaden your search
Search out to 75 miles. That will give you 4 possibilities with one about 60 miles from your location. Give them a call and see if they will travel that far.0 -
If...
If you can't find a company to come out in good time, you can contact me to take a look at it. I'm in Rahway, so the trip isn't really worth it for me unless all other options fail.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 27 Recall Announcements
