Corrosion on Buderus indirect fitting
D107
Member Posts: 1,906
(See attached photo). This 5 year old Indirect works like a charm but having watched the buildup of rust at lower fitting entry into tank, I was wondering if there's a simple fix, rather than having to remove, re-putty and re-install. Possibly to wirebrush rust away, and seal on the outside with something. Or just leave it alone?
I would take....
a wait and see approach. Sometimes they "leak" to a point then stop. There is noting that you can do to fix it other than draining and pulling it apart teflon and dope.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
