Steamed
NickM
Member Posts: 25
Dear Gentlemen,
I hired a self proclaimed Pro (who professes to have 40 years experience installing steam boilers) to replace my coal conversion. I did an accurate radiator survey and came up with 955 sq ft. The structure is a three story wood structure built in 1900. He was suppose to install a Burnham V903A while I was on vacation. When I returned, much to my dismay, I found that he installed a Burnham V89VSL. He had a whole bunch of reasons why he did it, (height issues, pipe sizes..) all of which proved to be wrong. He also told me that the V8 was already overkill and he had to down fire it because it made steam too quickly
The installer is a nice guy and I really dont think he did it out of malice or wanting to make an extra hundred dollars
He has offered to rip it out and replace it ... but I know that would hurt him in the pockets
I am concerned with my long term costs
Should I keep the V8
Is it possible he is correct by saying it makes steam too quickly and he needed to down fire it ?
Can anyone see any problems with the installation ?
Thanks for all of your help. if it wasn't for the Steam Wall I would have suffered at the hands of mechanics over the last three projects.
Respectfully
Nick
I
Respectfully
Nick
I
Header
The thing that catches my attention right off the bat is that does NOT look like a 3" header to me. Burnham calls for a 3" header MINIMUM on a V89.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
chris
Chris is correct that it call's for 3" and could be part of the issue your installer is having (why he down fired it). Next thing that comes to mind, did he skim the unit to start? And does he plan to return after the unit has had some run time to skim it again and wrap the pipes?0 -
More disappointment
I went looking for the Installation manual and discovered that the v89 is a 2009 model replaced by the 8H
This is getting worse
Thanks guys for your eagle eyes0 -
worry
As long as the (boiler) warranty is the same I wouldnt be to concerned with the model (unless its two years into the manufacturer warranty already, check with Burnham). I would be more concerned with proper sizing, piping, insulation and proper follow through. Did he replace all radiator and main vents? Did he flush the system? Again, resolve the pipe sizing issue and you may have the perfect system. I'm not a steam expert so I'll leave that to those who are, but dont count it out yet...you may find you have a perfect fit for your application, it just needs to be tweaked...0 -
Not sure of nuttin
I would like to say he did all of those things but I doubt it.
Where can I find the 3"min header in writing.
Can anyone tell me where I can locate the Installation manual for the V89 -- Burnham does not have one on line ?
I AM CONVINCED THE ONLY STEAM EXPERTS LEFT IN THIS WORLD ARE ON "THE WALL"
Thanks0 -
Burnham's website
Has been down for a while for some reason. Maybe because of the recent hurricane I don't know.
if you provide an email address I can email you the PDF for the V8 series. This shows minimum sizes for all of the V8 series boilers.
As far as V8 vs V8H I never found a difference. I had also asked on here regarding the difference and no one knew. I have a V83 which I just ripped out so I was checking part numbers as I was considering replacing the block. Both V8 and V8H even used the same block.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
here ya go
http://www.usboiler.net/products/boilers/v8h/
Click on the link towards the bottom right. If you look through the steam piping it show's B=3" page 350 -
Please Please Please
My email is
nmarchi103@aol.com
and I greatly appreciate your help0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
