How do you Purge ?
elvisman
elvisman Member Posts: 3
How do you Purge a Baseboard heat system with 3 Zones valves?
  • Slimpickins
    Slimpickins Member Posts: 359
    purging
    There is no simple explanation on purging because of the variations of near boiler piping. If you're a homeowner, I'd recommend calling a company that specializes in hot water heat .Plus its always good to have your systems serviced to prevent problems down the road.  A properly installed system should not require annual purging.  If you try it yourself there can be problems that could present a dangerous situation such as dry firing. Good luck!
