Heat pump TXV?
How does a TXV handle the reverse flow of refrigerant in a heat pump?
  • James Day_2
    James Day_2 Member Posts: 191
    txv
    a heatpump txv has a built bypass.  When it goes one way it gets metered into the evaporator,  when in heatpump mode it Bypasses and allows full flow through it.
  • Techman
    Techman Member Posts: 2,143
    A couple of ways
    Some use check valves to go around the TXV, some use a newer type of BI-flow TXV.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,591
    Thanks!!
    Thanks!!
