If our community has helped you, please consider making a contribution to support this website.  Thanks!
Heat pump TXV?
                    Robert O'Brien
                    Member Posts: 3,581
                    How does a TXV handle the reverse flow of refrigerant in a heat pump?
            txv
a heatpump txv has a built bypass. When it goes one way it gets metered into the evaporator, when in heatpump mode it Bypasses and allows full flow through it.0 -
            A couple of ways
Some use check valves to go around the TXV, some use a newer type of BI-flow TXV.0 -
            Thanks!!
Thanks!!To learn more about this professional, click here to visit their ad in Find A Contractor.0
 - 87.2K THE MAIN WALL
 - 118 Chimneys & Flues
 - 113 Geothermal
 - 164 Indoor-Air Quality
 - 73 Pipe Deterioration
 - 6.4K Radiant Heating
 - 393 Solar
 - 15.5K Strictly Steam
