Oil Safety Valve Install
LittleT
Member Posts: 6
in Oil Heating
If your furnace blower fuel pump is 100 psi + what should be the requirement's for an Oil Safety Valve pressure limits and what is the normal size of fuel lines for a single line furnace I'm thinking 3/8 ?
Thank you !! any help would be appreciated
normal size
The normal size depends on the pump, how far from tank, how much lift, size of nozzle/firing rate. Oil safety valve goes on the tank to prevent the tank from leaking in the event the oil line breaks, preventing gravity flow from empting the tank.
The oil safety valve isn't under pressure, so I don't know what you mean by 'pressure limit'. A vaccuum allows oil to pass.There was an error rendering this rich post.
OSV
OSV valves are generally only required when the tank sits above the burner.0 -
Compliance
Are you attempting this to comply with the recent Massachusetts law?0
- 167 Indoor-Air Quality
