Venturi Tees
Glen Aspen_2
Member Posts: 52
I am looking for the cv of either the 1 x 3/4 or 1 1/4 x 3/4 venturi tees; failing that an approximate fthd or milinch pressure drop (or equivalent length) at design velocities would be helpful.
Taco-HVAC.com
Go to www.taco-hvac.com Products/Hydronic Accessories/Fittings/Venturi Tee fittings/Catalog0 -
Two btu per sq ft for degree difference for a slab0
- 167 Indoor-Air Quality
