tankless back up to solar
geo_29
Member Posts: 2
I am wondering how to use my existing tankless water
heater as a back up to a new solar water heating system. It is a Bosch 125HX
that modulates based on water flow not temperature. It picks up water temps by 90 degrees. We are planning on a three
way valve before the tankless to bypass it when the solar water is hot enough
for use.
But the question
we need a creative answer to is how to avoid super heated water when we have
90F water going into the demand water heater?
Another question is how to get even
temperatures from the system, even at variable flow rate.
for use.
But the question
Covers it in depth
http://www.buildingscience.com/documents/reports/rr-0806-tankless-solar-hot-water-heating-integrationTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Check out
Bonomi valves. You can lay them out in any flow configuration and they have the lowest turning torque of about any valve. That means ypu can use a small Bonomi actuator. I believe they are at bonomi.us. You then have to co-ordinate the tank temp to bypas the tankless with the flow capability of the tankless.0 -
tankless in Europe
is a huge market. So Caleffi has developed a few valves, thermostatic and motorized to work with all types of tankless either modulating or not.
Issues with flowrates, water quality. etc need to be addressed for the US market. Maybe....
hrBob "hot rod" Rohr
the simplest answer
for part load DHW in many cases is just use an electric on demand that can modulate. your service has to be beefy enough to handle it. but by the time you jump through the hoops required needed to make gas boosting worthwhile, you don't save that much.
any cost differential between electricity/gas is a minimal concern when it is only doing part load on DHW like this. the solar will do the heavy lifting in most cases.Rob Brown
actually
If you read some of the tech literature with this unit it only allow's for "cold water" to the inlet. It clearly states you cannot use pre-heated water in this system and it will cause issues...
"Verify the heater is being feed with cold water only. This water heater is not designed for preheated water or recirculation applications"0 -
I completely concur with Ichmb.
This series of Bosch units is particularly prone to problems if the entering water temp exceeds 60 deg F. Bosch makes an tankless unit that is "solar ready". But this is not one of them. Time to regroup.0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
- 17 Recall Announcements
