Looking for good Caleffi hydronics distributor for radiator valve
rklopp
Member Posts: 3
I am trying to get my hands on a Caleffi 4501 radiator valve (plus an extension tube and compression fittings) in Northern California. My local supplier is not getting anywhere. Any ideas on who I should try?
Thanks!!
Thanks!!
Caleffi
Have you tried Power Boiler Sales in Richmond?
(510)548-9200
or email Bruce Tompkins in sales at norfitz@aol.com8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Do you have Johnstone supply?
Here in Maine, Johnstone Supply carries Caleffi.0 -
where did you get that #
maybe from our international catalog? We do not currently offer that valve here in the US. The products we offer for the US market are listed on the www.caleffi.us website.
hrBob "hot rod" Rohr
International Catalog
Yes, I must have gotten that number from the International catalog. This Caleffi is the only valve I can find that will let me regulate the bypass 0-100% and let me convert a Runtal towel warmer to a one-pipe setup. I am looking for the 450140 model, which is the 1/2” model, plus a model 453020 extension tube and two 437516 compression connectors for 1/2” copper tube (5/8” OD = 16 mm).
I've looked at everything from Danfoss to Watts to B&G to Taco to Buderus to Honeywell to Apollo, and I cannot find a valve that will do what the Caleffi one will do.0 -
Europe
Do you have any contacts in Europe? If so, order it from them.
Hot Rod: If it's a 1/2" valve, it should be no problem to get it there. Correct?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Single Entry Valve
Be more then happy to UPS you one if this does it for you..
http://hydronicalternatives.com/Steam-to-hot-water-conversion-valve.pdf
See page 3 below:
http://hydronicalternatives.com/Radiator_Accessories_07_2011_U_WEB.pdfThere was an error rendering this rich post.
Now we're talkin'
HVHEHCCA
That looks like it might be the ticket! I wonder why I could not find it before. Let me check my pipe center distance and I'll get back to you.
Thanks very much,
Rklopp0
