Converting to tankless
John1963
Member Posts: 1
I have an old oil fired boiler and want to change to a tankless system. The boiler does both heat and hot water would I need two systems or one. Also I am in the process of designing a kitchen and bath remodel and would like to do in floor radiant heating. Can any one give me some suggestions
A good answer...
... to your questions would fill at least two books.I suspect that's why nobody has answered you so far. There are questions of fuel type; efficiency improvements to the home (so the heat maker/s get sized right); type of system/s; condensing or non; sizing; and so on.
Why are you thinking tankless is the way to go? Condensing tank type might work if you have gas, or a good boiler with indirect, or... I imagine smaller questions will be easier for us Wallies to deal with.
Yours, Larry0
