air supply to Carlin EZ-gas
Just installed Carlin EZ-gas to Weil Malain. Unit has new design with cover. What size air supply line from outside air is required? Looks like adapter on cover is for 3 inch inlet but that seems too small to me. No info provided from Carlin. Who has installed these and what size duct did you use?
    Steamhead Member Posts: 18,209
    You don't necessarily need to use a duct
    with the acoustic cover. They give you a screen to use on the intake opening if you don't install a duct.
    What is your input rate?
    Consulting
  • Carlin acoustic cover
    Cover has 3 inch connector. Is 2 in or 3 inch pvc vented from outside adequate for the EZ-gas?
    edited July 2011
    Depends
    on the gas input rate. This affects how much air is needed.
    Which model W-M boiler do you have- SGO or WGO or WTGO-(some number)?
    Consulting
  • chillybob
    chillybob Member Posts: 1
    Carlin
    I have a WM 468.
    system running at 150,000 btu/hr
