Burner Mounting Plate for a US-25
CJM
Member Posts: 1
I am searching for the burner mounting plate for a US RADIATOR boiler Model US-25-4. If anybody can suggest a potential source for older 1950's era cast iron boiler parts( like an auto wrecking yard of boilers), I would greatly appreciate it. If anybody has the part, that would be even better!
got a picture.
Can you put up a pic of what your looking for? Or a pic of where it mounts. I'm heading over to my father's (he's 78) house/boneyard in the basement. Who knows what I'll find. I personally never saw one, but there may be something close that will work. At the very least he may have a book showing the part, and you can have someone fabricate one.
Also have to state the obvious. Replacement time? But I'm sure if that option was available to you, you would already be on that path.
Hopefully some of the very experienced (nice way of saying old-timers
?) may be able to help. There was an error rendering this rich post.
Take a pic of what you have
and post it here. Been a while since I've seen a US-25, but a stock mount or piece of iron plate might work OK. With that said, you would get better efficiency from a modern boiler.All Steamed Up, Inc.
Consulting0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
